Thanks.
That didn’t do it..........what eventually worked was refreshing “things” within the Stringify app. Problem seems to happen when app hasn’t been used for an extended amount of time.
Thank you.
Paul_FCCL,
Force close the app and reopen, are you still seeing the same issue?
Thank you.
I'm getting the same "access token is expired". What's the fix? Closing out the app doesn't help.
glavine16,
Reboot your mobile device, are you still experiencing the same issue?
If you’re using other apps with Arlo (stringify, ifttdt, etc.) look above for suggested solution.
