Access to a deceased persons system
You an PM a moderator here on the forum such as JessicaP to state your case.
@Mindycason , I am tagging @JessicaP. That will bring this issue to her attention.
Hi Mindycason,
I'm sorry to hear about your loss. What you could do is factory reset the Arlo devices that your father owned so it gets removed from his account and then add the devices to your Arlo account. Read here to learn how: How to factory reset Arlo devices?
Unfortunately that won't work unless you know his login credentials.
@jguerdat wrote:Unfortunately that won't work unless you know his login credentials.
I thought the same thing when I read the response.
@Dannybear wrote:
Also fascinating is that you can now factory reset the Pro2 cameras themselves individually according to the knowledge base.
Not sure if that is a new feature, or if the KB article is mistaken. If anyone has sucessfully executed the reset procedure on a Pro or Pro 2, it'd be good to hear from them.
@Dannybear wrote:
Suggest you get the deceased estate lawyer to write a request to arlo to have the asset ownership transferred.
@Mindycason: That might not be necessary. I suggest sending a private message to @JamesC and see if he can help (he'd need details that you shouldn't post publicly). You do this via the envelope icon in the upper right of the forum page.
If you know your father's email address, then include it in the PM (since it would also be his Arlo account username).
