  • 5 Replies
  • 8194 Views
  • 2 Likes
  • 5 In Conversation
polyicarus
I have change the sensitivity all across the slider and it will not start recording in time. I have it set up by the front door, looking down a 20 ft straightaway and by the time it start recording, i am opening the door. Any ideas?
5 REPLIES 5
The sensitivity setting is in your modes and rules, not in the motion detection test. Which are you trying to set? Also, motion detection works best with motion across the FOV, not directly towards it. You may need to reposition your camera for a better location. Post a screenshot for suggestions.
steve_t
Master Master
PIR motion detectors aren't very good when you move directly towards them. If you imagine multiple beams coming out, the heat signature is easier to detect if it moves across the field. I'll add a link in a picture
So best to position the camera off to one side. I actually have 2 cameras that cover my driveway. One looking down it and one looking across it. Each one is set to record as well as trigger the other camera (using 4 rules in the custom mode). This works really well but obviously means 2 cameras covering the same area
PIR zones
http://www.diycontrols.com/images/wisdom_wireless_pet_pir_range.JPG
wlc
Can you clarify how you do this : "I actually have 2 cameras ...  Each one is set to record as well as trigger the other camera (using 4 rules in the custom mode)."   What are the 4 rules in the custom mode?  I want to create a mode where both cameras record when either camera detects motion first. Is that possible?
manfredz
Hero
Hero
in case you dont know how to make rules read up in the FAQ.
Then, lets just call the cams A and B
make rules if cam A detects motion start recording cam A
                   if cam B detects motion start recording cam B
                   if cam A detects motion start recording cam B
                   if cam B detects motion start recording cam A
steve_t
Master Master
Additionally, I'll add that my rules have it so when cam A motion causes cam A to record, it's for 60 seconds or whatever and when Cam A causes Cam B to record, it's for 75 seconds (or whatever). And do vice versa. This way you can see that if the recording on Cam B is 75 seconds long, it was actually Cam A that detected the motion originally. It works really well 🙂
