I've got camera that shows up and functions perfectly under the "Devices" tab of the app. It won't let me add the Camera to the "Dashboard" tab of the app.
When I try to add it to the 'Dashboard', it goes through a process of trying to discover the camera, which is already discovered and online with the base station. It says it can't find the camera that is functioning perfectly in the "devices" tab.
I'm really getting sick of this worthless APP.
Select "Add a Widget" on the dashboard screen - not "Add a Device". That will add the camera tile to the dashboard.
"Add a Device" is the same as the "Add a Device" on the devices page, and you cannot add a camera to your account twice.
Thats it!
Thanks!
