  • 2 Replies
  • 4809 Views
  • 2 Likes
Retired_Member
Not applicable
Hello,
I just unboxed a brand new arlo pro 2 kit with 4 camera’s. The first 3 sync’d immediatly. The 4th one doesn’t sync. The blue led is blinking, but after a few seconds it starts to blink amber and stops. I tried to restart the hub and switch batteries, but no help...
Camera 2 & 3 firmware update works, but the first camera won’t update and I receive error code 4208. The led on the camera is blinking blue/amber. So I inserted another battery and it worked. Does this mean the first battery is bad?
Thank you
There can be various reasons for this but I'd start by removing all devices from Settings, My Devices and start fresh to get rid of any weirdnesses.
Retired_Member
Not applicable
It worked!! Thank you for the quick reply and help!
