4 Arlo cameras, base station and a new Netgear R7000 router but push notifications don't work now
  • 1 Reply
  • 2773 Views
dawionnen
We have been using Arlo VMS3430 cameras.  Worked good!  We changed to Netgear R7000 router from an old ATT router/modem and now push notifications do not send info to Email.  Is it compatibility issue or something wrong in the router?
The router should make no difference....
Also, pushes and email are two different things and work differently.
I would re check the settings for email/pushes to verify they are checked off.  Another test if email  issue is to send a test email to same accout from another device to verify email account is good.
