I keep having an issue with the system going off line.
Currently there are 3 out of 5 green lights on, the system shows its armed, yet none of the 5 cameras are on line.
This is the third time this month. What am i doing wrong?
Sir I have the Arlo wireless 2 camera. I changed out the provided Cat5e cable and I replace it with a Cat6a cable. The problem went away.
A couple of quick things to try are logging out and back in and/or restarting the base by the power button or the Restart button in Settings, My Devices, your base. Are you experiencing any power outages? if so, a UPS for your modem, router and base is a good idea.
I have updated the app, tried the restart on the base and my phone. There have been no power outages. Still nothing. The problem started after the app update.
The system is armed but no recordings.
The app has no effect on recordings - only your settings as stored in the base. Verify your firmware versions in Settings, My Devices, your various devices compared to those found in the Release Notes section here.
Worst case, you may need to reset the system and start fresh.
I will take your advice and see what happens and will post a follow up.
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy925
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,070
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
