2nd camera won’t sync
  • 1 Reply
  • 3410 Views
Yamahamoto
I managed to set up the 1st camera but the 2nd just won’t sync. Kept on blinking blue light for a while and shuts off.
Has anyone got the same issue and know what I should do please? Thanks a lot in advance
Move your base as far away from your router as the cable allows...
Open camera and pull then replace battery to reset camera.
reboot the base with the power button ( off then on ), allow to come back about 2 mins
QUICK press on base sync button, then camera button
