Added my second arlo, the original guit giving motion notifications. It works fine live
Does it have camera recording rules when you can check or uncheck the boxes for notifications and/or emails?
Yes, when you add a camera you must manually add a rule for it in your modes.
Check if your new camera is armed (the gray running man in the app/website). If it is not, you should add a rule to any (or all) of the modes to make it arm and record.
If it does, keep in mind when notifications overlap you only see the last one. I have that on my front porch, there are two camera's that usually trigger after eachother. Only the last one remains in the notifications panel of my android phone, but the first one did notify me as well a few seconds earlier and the recordings are in the library.
