2 cameras have stopped working batteries are fully charged yet gives message time to change your bat
First you say the batteries are fully charged.... Are you using rechargeables? If so what type and voltage?
If using OEM cells, open the battery door for a few secs,, then close.
Try a power button reboot of the base.
If that doesn't work, then go to settings for each camera, use REMOVE DEVICE.
Now one at a time bring each back as if new(resync)
