2 cameras have stopped working batteries are fully charged yet gives message time to change your bat
  • 1 Reply
  • 2447 Views
AllanS
First you say the batteries are fully charged.... Are you using rechargeables? If so what type and voltage?
If using OEM cells, open the battery door for a few secs,, then close.
Try a power button reboot of the base.
If that doesn't work, then go to settings for each camera, use REMOVE DEVICE.
Now one at a time bring each back as if new(resync)
