1 of 5 ARLO offline, will not resync
  • 1 Reply
  • 2696 Views
honuhonu1959
This ARLO device is offline. Re-synced, flash slow blue, fast amber, fast blue.  No change
This ARLO device is offline. Replace batteries. Re-synced, flash slow blue, fast amber, fast blue. No change.
My other 4 cameras on this base station are fine.
This ARLO device is offline. Clean contacts, not that they needed it. Reset batteries, Re-synced, flash slow blue, fast amber, fast blue
No change, Still "This ARLO device is offline"
Did you also remove the camera from Settings, My Devices before resyncing? If not, try that method. If still no good, open a case with support here.
