I just set-up my 3 camera system. Two of the three are in color and one is in black and white. How do I change that one to color?
BT
B&W is night vision. Increase the light level for color. If it's dark enough you should see the IR illuminators light up the scene.
how do you set for all cameras to have colr?
Is there a desktop icon so you can view the pictures?
How do you access the cloud to view?
Thanks for your help in advance..Bob
They default to color if there is enough light
Go to HTTS://arlo.netgear.com
By playing back one of the recorded videos or snapshot via apps for IOS/Android or the web as above
That's "HTTPS" for the finger-challenged...
maybe more the second glass of wine ! 🙂
