I just added a third camera to my two camera system. Had no problems with install and it works fine. My issue is it does not display the last image recorded, it has a green screen that says press live button to see your new camera in action after I log back on. My two original cameras show the last image captured.
Yes that is the fix. Go to settings, devices, the problem camera and remove it from system. Then bring to base station and sync.
two things...
1) try and reboot the base via the power button
2) restart or clear the cache in you browser
I tried your suggestions to no avail. I'm using iPhone and iPad for viewing.
Hi, I have the same issue. What is problem.
WildBill, Sakiboy
This is the default message you will receive on a new camera until you live stream the camera for the first time. Does this message remain after you initiate the first live stream?
Yes it comes back after I log out and back on. It displays the image as long as logged on.
