  • 1 Reply
  • 973 Views
Tyler13
I would like to have 1 camera armed at all times and 2 cameras based on geofencing & schedule. Setting it up as geofencing & a schedule is easy, but is there any way to make an exception for one camera or do they all have to operate under the same parameters? Thanks for the help!
Offhand thinking about it... there are only two options for geozone... home and away ( which either can be any mode ).
But since you can't run more than one mode at a time, it may be very difficult to do.
The quickest thing I can think of is to purchase a second base unit... then it becomes very easy and you also can expand your coverage area.
( I run more than one and prob the best feature is running more than one mode at the same time )
