Arlo VMB3000 Base Station shows amber LED on router. Help? Worked fine for a couple of months.
  • 2 Replies
  • 993 Views
rsbobiles
It works fine for a couple of months then suddenly stop working, on base station solid green light and flasing sometimes, but on the router the color is amber, what will I do
first, unplug and replug in base... let it reset.
Actually, that color on the router is correct. The base uses 100Mbps connections on the Ethernet cable since gigabit is totally unnecessary. The typical router shows and amber light when connected to 100Mbps devices.
