So somehow one camera drained it's battery overnight in less than 12 hours. It was not left running and did not record ANY motion during this period. Is the camera defective or is it possible the update caused a problem with this one camera ? Kinda annoying as these batteries aren't cheap and I now either have to exchange the whole system or purchase 4 new batteries and hope it doesn't happen again.
This is what the image looks like now on that camera. Is that due to the low battery or is the camera truely defective ?
https://arlo.netgear.com/hmsweb/users/library/share/link/76562EEF9238D645
Hi @AnthonyArmato,
Your cameras certainly should not have drained overnight, and it sounds like the camera may have been old older firmware where we had mis-reported battery life issues. The current firmware version for Arlo cameras is 1.2.22412. A one time power cycle may be needed by opening and closing the battery compartment door to clear the inaccurate value. We apologize for any inconveniences this may cause.
In regards to the pink tint on your camera, this is camera image distortion and is not expected behavior. Please reset your camera by opening and closing the battery compartment door. This should alleviate the tinting issue, but if it does not, please let us know and we may need to open a Support case.
I look forward to your next update!
Best Regards,
Lauren
Arlo Team
That did fix the color issue but the battery level remained the same (Red).
Today, my image is back to the red coloring again !
Hi @AnthonyArmato,
Thank you for the update. I will send you a private shortly so we can take the next steps.
Best Regards,
Lauren
Arlo Team
Okay, thanks.
Hofmannpj,
