I am interested in your Wireless doorbell cameras and want to know if you have a solar charger for that? Is the video recorded to the cloud and what might that cost? Would be so much easier to speak to someone how would I if I buy this stuff and have an issue?
The wired video doorbell charges from the existing wiring. A solar panel would be redundant as well as hard to implement. Video is recorded to the cloud and costs $2.99US after the free 3 month trial ends.
The forums are the quickest ways to get help but with that subscription you have the ability to speak with Arlo support.
Im asking about Wireless doorbells and solar chargers, then after the 3 month free it $2.99 a month?
As @jguerdat says, there is no solar charger for the doorbell. Note the wireless doorbell will trickle-charge from the low-voltage AC in existing wiring, so if you have an existing chime then you wouldn't need one. There are also some plug-in adapters available that will work.
Yes, you will need a subscription to get cloud storage (needed for all video recordings), and also activity zones.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
