door chime 2
  • 1 Reply
  • 797 Views
ph2023
Hi everyone,
I'm looking for some help with the door chime 2. i have 3 wireless doorbells currently set up and working from 3 different doors. how many door chime 2's can i have assigned to a system?
can i have a door chime two operate from all three doorbell cameras with a different tone for each door camera so i can identify which door is being used?
ideally i would like at least 6 chime units that can operate across all three doors with a different chime for each door, is this possible?
many thanks for any help you can give. its much appreciated.
Peter
ShayneS
HI @ph2023
Sorry for the delayed response, I was checking in with the appropriate team for the best answer to this. You can use as many chime 2 devices as you like and you can assign a desired tone to an individual doorbell for when the button is pressed.  so basically, if you have let's just say "5" doorbells, you can have a different sound ring for each doorbell from "one" chime 2 in your home if you like.
  • 1 Reply
  • 798 Views
