  • 974 Views
Toledori
I have been having a constant issue with my arlo video doorbell. I have had it doe nearly a month and on an average. Every 3 days, I get the
"Your doorbell is not connected. Make sure is connected to your Smart hub and has working internet connection"
I'm currently using smart hub 4540 and 5 other arlo pro 3 cameras. None of the other cameras give me issues. The smart hub is on the room above the doorbell, so approximately 8 ft distance. I have cameras farther from the hub that have given me no issues.
Every time I have gotten this message, I would shut off the breaker and do a factory reset. Go through every step. It would literally take me about 5 factory reset for it to work. Even though it would find the doorbell every time, I would still get the message, so I would have to factory reset again.
Yesterday, I got it again, but this time it doesn't want to stay connected. It will find the doorbell during the installation process but I would still get the error message. I have an 18v doorbell connection so it has power. And when I get the error I get the white blinking light.
What else can I do? I would like for this to stop happening.
Thanks in advance
Toledori,
Is the doorbell connected to your SmartHub or directly to your home router? If you change how it is connected, do you still experience the same behavior?
Toledori
Since the day it was bought. It ha abeen connected to my smart hub. But since I had posted this message. I have tried both my wifi router and the hub, following all steps and the doorbell it's no longer found. It would blink white for a few minutes, the it will blink orange and back to blinking white.
I would then get the error message, no products found by the arlo app. I would look at the doorbell. And it would be solid white
If you've factory reset and you still are unable to onboard, I encourage you to reach out to the support team through the Arlo mobile app to open a ticket and investigate further.
  • 975 Views
