Wired video doorbell stopped chiming.
  • 5 Replies
  • 1130 Views
DJ51
My Arlo wired doorbell has stopped chiming. All wired still connected.
5 REPLIES 5
Are you still getting alerts?  And livestream the camera?
DJ51
Yes, still getting alerts and I can live stream.
Ok.  Are you using a traditional chime or are you talking about an Arlo Chime/Chime 2 that stopped working?
If this is a traditional chime, is there another doorbell connected to it? Or only the Arlo?
DJ51
This is a traditional door bell. I have only the one Arlo connected.
Then the puzzle is to sort out whether the doorbell or the chime has failed.  I guess it could also be a transformer issue.
You can test the chime by disconnecting the doorbell and then touching the two wires together at the door.  If the chime sounds, it is still functioning.
Have you installed the power kit?  You might also want to check that it hasn't ended up somehow in bypass mode (switch in the X position).
  • 5 Replies
  • 1131 Views
