Wired doorbell not getting power
  • 4 Replies
  • 828 Views
christel_joy
I moved to a new apartment and am trying to set up my doorbell again (Gen 1). I know there's power but it's not lighting up to connect. I couldn't fully shut the power off when installing, could have shorted it out? Any fixes?
Arlo Essential Wired Video Doorbell
Do you know the voltage and power specs of the transformer?
christel_joy
I don't even know where the transformer is lol. Is that the fuse box?
No.  The AVD1001 needs low-voltage ac (16-24 volts) with at least 10 VA (volt-amps)  of power.
You might not be getting sufficient voltage or power at the doorbell.
It also needs a power kit installed at the chime - is that installed?
christel_joy
Oh I think I found the transformer in the closet behind the chime box. Of course it's right above the door & difficult to see. It may be the wiring to the chime box as well - it's a musical box that looks 40-50 years old, doesn't have typical wiring.  I may call an electrician, just wanted to make sure I didn't short out the doorbell during install.  Thank you for the help!
  • 4 Replies
  • 829 Views
