Hello, I have lost my power kit and the voltage does not reach what is necessary to turn on the video doorbell. What can I buy or where can I find a solution?
Best answers
MatiasBresa,
The Power Kit is not available individually for purchase. Please contact the Arlo Support Team You will find several options for contacting support in the provided link.
MatiasBresa,
I contacted the "Contact Us" liink.
They asked me to call the Sales number: 1-866-703-7170
I called that number.
The person on the other end said "We dont sell them online". But you can check "local stores".
She gave me the part numnber, which is APK1000
She couldn't provide a list of local stores that might have it.
I have checked on amazon.com, bestbuy.com, homedepot.com
None of them have this part.
I need an extra one because my house is wired with two mechanical chimes.
Any help would be appreciated.
Normally the two chimes are wired in parallel - and if they are wired that way you only need to attach the power kit to one of them.
You can easily check if they are wired correctly - just disconnect one chime, and see if the other chime rings when you push the bell. If it does, they are wired in parallel.
I will try this out.
Btw, I did contact Arlo tech support, and they told me I will need two!
I have two mechanical chimes also - and two Arlo doorbells. I need two powerkits total (one for each doorbell).
Thank you.
I verified that my two mechanical chimes are wired "in parallel" to each other.
I have now installed my Arlo Video Doorbell (Wired) with the power kit installed on one of the mechanical chimes.
And everything works great.
Did you find the part APK1000 ?, I need it too.
Is something wrong with the power kit that came with the doorbell?
I need one as well. I've moved and forgot to remove it...
Now I'm stuck. How do I install with out it? When I connect power, my chime just keeps chiming!
Tony
Wow, I cant believe there is no where to buy the power KIT....that blows me away. I need 1 also
Not very good business, the way i look at it.
Has anyone had any luck finding a power kit to work with the Arlo doorbell? I can't find one anywhere. I'm wondering if the Ring power kit might work. Thanks-Mike
Just got off with customer support. They said they'd escalate the issue, but couldn't guarantee anything.
Did you try the ring power kit? It looks like you can get one for $2. I figure it's probably worth trying before I throw the whole thing away and get a different product.
To follow up: Arlo did sent the part promptly and it appears to have resolved the issue. Hopefully they'll be able to do the same for future customers that have this problem.
Hello, i burned out my power kit, im trying to talk to someone in order to buy one extra.
how can i get in touch?
If you have a subscription you can try phone support.
But Arlo doesn't sell them separately, and AFAIK support can't supply a powerkit w/o a doorbell. Which seems crazy, since sometimes people do need a replacement.
Has anyone had any luck with the Ring power kit? Arlo customer service is absolute garbage and unwilling to help.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
