Was having a lot of difficulty setting up starting at the point where the doorbell connected to the base station. Attempted setup 20+ times, did every troubleshooting method on the internet.
Then.... it literally just stopped. Device wont light up, wont react to any stimuli for lack of better terms.
There is definitely power flowing, by the way. I checked. Did it get overworked and get fried or something? Has anyone experienced this?
If pressing the reset button for 15 seconds doesn't bring it back to life, then you should contact support using https://www.arlo.com/en-us/support/contact.aspx
https://kb.arlo.com/000062346/How-do-I-reset-my-Arlo-Video-Doorbell
If the doorbell has failed, then you might find it easier/faster to exchange it with the seller.
What voltage are you measuring?
The doorbell does have a small internal (rechargable) battery - and if that drains I think the doorbell might be non-responsive for a bit.
Replacement just came, I guess we'll give device #2 a shot.
Did your second unit work? I received a second unit as well and it will not power on at all. Very frustrated and want to get my money back for this expensive piece oof plastic hanging from my house.
ProATC,
If the doorbell will not power on, your transformer may not be providing enough power to meet the minimum requirements. Take a look here for more information: How do I measure the voltage of my doorbell transformer?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
