I am installing an Arlo Wired Video Doorbell and it’s not connecting to my WiFi.
I am on fiber and only has 5ghz, but the instructions indicate that the network should be 2.4ghz
Is this why it isn’t connecting and what should I do?
Are you sure? Almost all 5 ghz routers also provide 2.4 ghz. What manufacturer/model is the router???
I am also having this problem, but dont think anyone has a good answer on how to fix.
Which device are you experiencing this with? May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
i have the same problem. I contacted support by chat and was told to see me router tech!!! I have a up to date router and its fast and has no issues.
I am completely disappointed in the chat help and should have looked at the comments by others before I ordered this thing. I am 2 hours into trying to fix something that is out of date the day it arrived at my house.
Hi @Sparty1976
Is this the first time trying to install the doorbell?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
