Video Doorbell does not record
Bob_CA,
First, your Arlo Video Doorbell needs a subscription to an Arlo Smart plan to save recordings to the cloud. If you have an active Arlo Smart subscription (or trial) recordings from the Arlo Video Doorbell will be saved to the cloud if the doorbell is Armed and there is an active rule telling it to record when motion is detected. If your Arlo Video Doorbell is synced to your SmartHub, log in to your Arlo account and navigate to Mode > select your SmartHub > check the active mode to make sure there is a rule present telling the Arlo Video Doorbell to record when motion is detected.
Thanks for your response James. That was very helpful, although I am still not getting recordings.
I have a 3 month Arlo Smart trial because of the 4 Arlo Pro 3 Cameras and the hub that I purchased, the the Video doorbell would not let me enable the rule to record. So I actually subscribed thinking that the free trial was limited to the 4 cameras. So, now I show all 5 devices subscribed to Arlo Smart. However in the Mode -> Armed -> Video Doorbell rule, the option for Record is greyed out, and I cannot get it to record - it tells me that I have to upgrade my subscription, but I already purchased the 5 camera plan. So, what's up? Does it take time to propagate? I'll check again in the morning.
Bob
So, a couple days later when I checked, the option to record on motion was no longer grayed out. So I enabled it and now I get recordings, but unfortunately I now get double notifications on motion - oh well, at least getting the recordings.
I should have gotten Arlo Smart automatically with the purchase of my video doorbell as the introduction email from Arlo indicated. I am hoping that my subscription is on hold until my free trial runs out...for the doorbell and the 4 cameras.
So, what I said before was based on the mobile app...the web interface still has the record button grayed out:(. Please fix the website.
My doorbell video camera was recording fine, set to local recordings on USB, until this week. I get motion alerts, but no recordings. There is plenty of room on my USB. When I reset the smart hub, it sometimes will record like it did before, but only for that evening. Then the next morning, back to the same issue. The last few resets didn't do anything. No recordings. Please advise.
Lowprofile110,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Does the Arlo Doorbell only record if you have a subscription? Is there an option to record locally? If so how do you setup the recording locally? My trial has ended and when I look to make sure the doorbell is set to record, it is greyed out.
rblastick,
Yes. Your Arlo Video Doorbell must have an Arlo Smart subscription for recordings to be saved to the cloud. You can utilize local storage if you have your doorbell synced to a base station or a SmartHub. For more information on local storage, take a look here: How do I set up local storage backups on a USB device using my Arlo base station?
Do you need a subscription to have the video doorbell records to the base station?
Isn't the subscription for cloud recording only?
My recording is greyed out on the Mode Rule and the doorbell is not recording. I no longer have the 90 days trial, but the doorbell is sync to my arlo pro 2 base station VMB4000R3.
Jrfvismanos,
For recordings to be saved to the library, you must have an Arlo Smart Subscription. For more information on Arlo Smart, take a look here: What are the available Arlo subscription plans and how much cloud recording is available?
but you can only view those recordings by manually ejecting the usb stick and viewing them on a laptop
This is so lame, it can record to the local storage but can cannot view it with the Arlo GUI interface. Have to connect connect my USB hard drive to laptop in order to view recordings. Other non doorbell cameras no problem. I purchased the VMB4500 specifically for local storage. If get the subscription (whopping $9.99 for my one camera), I can record/view recordings to Cloud. I just want to view recordings on local hard drive. Arlo should fix this, instead of forcing customers to pay for the Cloud service. When will it be fixed? I'm running latest firmware. Try calling support multiple times, always give me runaround, or disconnect me from the chats.
Update. So Video Doorbell camera according to Arlo support, only supports viewing library from Arlo if have Cloud subscription. Other cameras e.g Arlo2 can view from library if recording to Cloud or Local storage . Decided to pay for the $2.99 Single Camera plan for the Video Door bell. Will not buy anymore Arlo products until they fix this.
Exactly. I feel like I’m being ripped off from this arlo video camera doorbell. I have 4 arlo pro 2s with base station and that does not help with the recording. It should just be native for the arlo video doorbell to integrate with the base unit without subscription. We don’t need the other special features of the video door bell like package detection, we just need it to record movements. It defies the use of it to be force to get the unnecessary subscription.
Arlo should upgrade this base. I recently purchased this system with the understanding it will record video without a subscription. That is NOT true for this base. Do not purchase if you feel you want to view local recordings without having to buy a prescription.
IreneS,
If the doorbell is Armed, it should record when it detects motion, much like your other cameras. Check your modes and make sure the doorbell is configured to record when motion is detected.
I'm with ya. Running into the exact same issue. Very disappointed.
That’s incorrect. The doorbell obviously doesn’t record when you’re not subscribed monthly.
IreneS,
My point was I have purchased 3 other Arlo cameras each record up to 7 days which is what I wanted and all I need and they do this without a subscription. So when my son wanted to know what I would like for my birthday I thought why not get the door bell and yes here was my mistake...I assumed (ass-u & me) all Arlo products would work the same and so this is why I feel like this "lack of disclosure" that you MUST have a subscription for this door bell to record.....was and is a conscious effort on the part of Arlo to intentional deceive and then to coerce me into paying for a subscription I don't want. I read the instruction and the box but never at any time did I see anything about a subscription required (it appeared to me to be an upgrade option ) and until the Free Trial was over I had no clue it would not work like the other three I already owned. Sad and Confused!
So...... If I was to connect an Arlo wire free video doorbell, to my VMB4000 hub with 32gb storage, it wont be able to record/download footage without the subscription (which is what this hub is able to do)
Also, can you add the doorbell video to your phones camera roll?
TiA
It seems easiest to keep this thread alive. Please move this if it is in the wrong area.
I have a video doorbell connected through a SmartHub base station. 2 days ago my doorbell stopped recording. If the bell is pressed,, I get the notification to my phone. It will record if I answer the notification. It will not record if I decline it or do nothing. It also is not recording motion. I have changed nothing. My plan is active, my settings are set to record video if motion is detected.
If the responses to reset anything, OK. Then what? The point to these things is to surveil when you are not home. I do not check my library with any regularity to alert me that is not working. How would someone reset it if they are away for an extended period?
Thank you.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
