DylanPrather,
Is this the first time you've set up the doorbell or have you already completed the installation and it's gone offline?
DylanPrather,
What is the LED behavior on the doorbell? At what point during setup do you experience an issue?
I also did try to connect with the hub, but the video doorbell is not recognized. I am using Arlo base station with 2 cameras for 5 years already, never had problems so far.
I also connected the new Arlo chime to the hub without any problem.
Only the video doorbell is not discovered by Arlo. The white LED ring on the doorbell is blinking, so the doorbell is powered during the set up procedure.
Also connecting to Wifi directly instead of the base station is not possible. I see the QR code and the doorbell rings but no WiFi connection.
Tried to reset the base station and doorbell, but still the same issue.
Did you solve it ?
Sjef57,
Which model base station are you using? Take a look here for a list of compatible base stations: My Arlo camera is connected directly to my WiFi router; how do I connect it to an Arlo SmartHub or b...
You state that the Arlo Video Doorbell is not compatible with my VMB3000 Base station. Why is that not clearly specified on your website ? In the VDB “Tech Specs” under “Installation Requirements” there is no list of compatible base stations.
https://www.arlo.com/en-us/products/arlo-video-doorbell/default.aspx#techspecs
And the VMB3000 is still listed in “What are the minimum requirements for installing and using my Arlo System”, in combination with Video Doorbell:
Furthermore you state: “The only way to add the Video Doorbell is separately, but not to base station”.
I followed the installation procedure using the Arlo app, but after recognizing the QR code, followed by a chime signal on the Doorbell the installation procedure stops. The Video Doorbell is not recognized by WiFi directly. Also resetting the Doorbell did not help. The internet speed at the door is more than 40 Mbps. The VDB is powered with 24V.
Maybe a better solution is to exchange the Video Doorbell with the Arlo Audio Doorbell ? The Audio Doorbell seems to be compatible with my VMB3000 Base station. Can you confirm ? And I can use my existing Arlo cam to get the video signal when the Audio doorbell is pressed ?
I am experiencing the same issue. My doorbell worked fine until I got my wifi network replaced with a new one. Now I cannot reconnect to 2.4ghz no matter what I try. This is so frustrating. QR code chimes but doorbell cannot be found.
I decided to return the Arlo VDB and buy the Eufy doorbell. It has only good reviews
Recommendation to Arlo - please give users an option to add a new/reconnect a doorbell without going through the 20+ steps within the app to install the doorbell to the wall and wire the chime - the process is so annoying and wastes so much time when you have to repeat it 50x in order to figure out how to get the doorbell connected to wifi!!!!!!!
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
