Use Arlo video doorbell with NO existing wired doorbell
  • 7 Replies
  • 9638 Views
ArneDK
Hi,
Is it possible to install the Arlo video doorbell without existing wired doorbell only using a transformer with the correct voltage and amp?
Arne
7 REPLIES 7
Yes. That's exactly what I do. The doorbell will still generate a call to your phone when pressed.
Hunga2020
Hi, can you guide me how to set it up? I look for that to install for my front door, 🙏🏼
Follow the installation directions but skip through the part about connecting an existing chime.
Neil1923
I am trying to use without existing doorbell. I have managed to get to the part where it scans the code but it does not find the video doorbell? What do I do?
You may need to try the reset procedure found in the support FAQs here. Do you get the appropriate light ring conditions as you connect and try to set up? Are you connecting to a base or SmartHub or to your WiFi?
Neil1923
Thanks for your reply.  Yes I had the white circle showing. The QR code went beep but then it searched but could not find the doorbell? I am using wifi.  Regards Neil
I'd start by resetting the doorbell as described in the FAQ here. It may also be worth setting your phone to use your 2.4GHz SSID.
  • 7 Replies
  • 9639 Views
