  • 2 Replies
  • 1451 Views
nareshnayar
Terminal screws on the essential Arlo Video door bell are too tight and strip easily.  I have tried two of the video door bells and I am able to loosen one of the screws,  the other  ones gets stripped.   Using a #1 Philips screwdriver.  Have other folks run into this issue?    Thanks for any pointers/help.
At least part of the problem is the use of a #1 Phillips screwdriver. Use the LARGEST screwdriver that fits. ALso, be aware that there are different tips even within the proper size - I use a #2 that has a point on it rather than a blunt end.
Psthepvongsa
Both terminal screws were stuck. I used several different screw drivers and they would not budge. The screws were overtightened during manufacturing. I was so afraid I'd strip the screws. Finally my last ditch effort paid off. I used a manual ratcheting screw driver with interchangeable heads. I had to press firmly and turn. Thank goodness because I was ready to give up. 🙄
  • 2 Replies
  • 1452 Views
