  • 6 Replies
  • 4023 Views
DUNKENBLITHS
I will actively persuade people not to buy your product until you fix this issue...
https://twitter.com/DunkenKBliths/status/1651137531914891265
I have a "VMB4540r2" and wish to not use the CLOUD anymore - While all the other cameras will record to USB on the HUB and I love it... the Door Bell will not accept USB storage
This needs to be fixed in your software immediately, or I will actively be promoting across all social media that you are false advertising that it can be used off the CLOUD...
Fix it !!!!
The base is doing the local storage, not the doorbell - so if the doorbell is connected to the base station (not your home wifi) then you should be seeing local recordings.
What model are your other cameras?
6 REPLIES 6
Just checked local storage here for both my doorbells which are connected to my hub (NOT WiFi) and they are definitely recording locally.
That is with Feed, correct?
DUNKENBLITHS
Thank goodness...for that... will withdraw my complaint...
When I bought the system I started with the Doorbell, so was connected to internet directly...
Thank you for sorting this out so quickly..
Just to finish this thread up, yes, it's with Feed (new UI) but the same would be true with the old UI.
Just to clarify - you are saying that local recording isn't working with Feed.  We don't know if it is working with Library or not.
It should be working with both.
  • 6 Replies
  • 4024 Views
