  • 4 Replies
  • 4682 Views
  • 2 Likes
frankstallone
With an appropriate power adapter and the correct voltage, is it possible to install a standalone Arlo Video Doorbell without having to connect it to an existing traditional chimes?   20-24 volt transformers are easily available, so I am wondering, has anyone else done this, and does the camera work properly?
Thanks!
That's how mine is set up. Works fine with just the phone getting calls from doorbell presses and videos at any time.
bobed
How is your set up wired?
I have contacted all out technical support three times and have gotten conflicting answers.
We would prefer to have no chime activated however have the video doorbell sent to our iPhones
Thanks so much for all of the help
If you have no chime installed, then you should be able to use just the transformer (w/o the power module).  Of course the transformer does need to be within the spec.
If you do have a chime installed (but don't want to use it), you can simply disconnect the lead on the chime for either front or rear (whichever is appropriate).
bobed
Great thanks so much for your help
I have a 16V 30VA transformer but prefer to have only iPhone notifications for us while having the chime disabled
It’s unfortunate that we need the community to provide info that should be readily available from Arlo tech support
Once again thanks!
  • 4 Replies
  • 4683 Views
  • 2 Likes
