  • 15 Replies
  • 5015 Views
Jo060
Luminary
Luminary
Back when the new UI released, there was the option to add a small widget to the dashboard. I've recently had to delete and add a doorbell and now my only option is to have a large or medium widget both of which show an image.
Have they done away with the small widget that just displayed the name and battery level?
I've added a screenshot
ShayneS
HI @Jo060
I was able to find some info, At this time the feature has been removed. I will continue to provide info if there are any updates regarding Small widgets for the Arlo doorbell.
15 REPLIES 15
ShayneS
Is this with iOS or Android? I still see the option for a small widget at the moment.
Jo060
Luminary
Luminary
For android
ShayneS
Can you verify which version of the app you are using?
Jo060
Luminary
Luminary
Version 4.2.5_28525
ShayneS
I should have clarified sorry, is this over the web portal or the Android app on you handheld device?
Jo060
Luminary
Luminary
It's in my phone.
Same issue online though. I can only add a small or large widget, both showing a small snapshot of the camera view.
ShayneS
Reading this statement:
"It's in my phone.
Same issue online though. I can only add a small or large widget, both showing a small snapshot of the camera view."
Are you trying to add a medium widget?
Jo060
Luminary
Luminary
Nope. In the attached photo from my original post, you can see that I have my widgets set up as a small square that only says the name and battery percentage. Now I only have the option for a small or large widget that displays a snapshot of what the camera last saw.
ShayneS
The small widget option you mention should be the small option available.
Jo060
Luminary
Luminary
I apologize, I mistyped.
I don't have the option for a small widget, only medium & large.
ShayneS
Okay, that's what I thought : )
Let me look in to this for you and I will update this thread as soon as possible.
Jo060
Luminary
Luminary
Thanks! I appreciate the help.
ShayneS
HI @Jo060
Jo060
Luminary
Luminary
Darn.
Thanks for looking in to this, I appreciate it.
ShayneS
You are welcome.
  • 15 Replies
  • 5016 Views
