Ring power supply with Arlo doorbell
Hi! I have this plug-in power supply: https://se-en.ring.com/products/video-doorbell-plug-in-adapter-gen-2 The specs say it outputs DC, so will it not work with the Arlo video doorbell? I’m getting mixed messages when googling, because it looks like the same generic brand power adapters work with both Ring and Arlo doorbells. Are those adapters outputting both AC and DC, or how can that be? Is there a possibility my new Arlo doorbell gets broken if I try? Can anyone suggest any EU plug power supplies (preferably white colored) that would definitely work? Thanks in advance for your help!
I can't suggest a transformer with an EU plug but this is the one I used for a while:
https://www.amazon.com/gp/product/B07VT6ZH5R/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I would think there would be many other similar ones that would have the plug style you need but you could always use an adapter.
No - both the AVD1001 and the AVD2002 need low-voltage AC.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
