Keep trying. There is a protective film applied for shipping and it should be removed. If you can't find a tab to start, just use fingernails to start lifting it up.
Were you ever able to get the film removed? Mine is the same way but it does not want to be removed.
These films can be a pain but definitely are removable.
There was originally a film that covered the whole face from the factory. If that's removed don't attempt to remove anything else - it's a cover for the PIR sensor.
You did read my reply just above yours, right?
You also contradicted yourself so there's that.
There's no contradiction in making sure that the film that covers the WHOLE face is removed vs. trying to remove a cover for the PIR sensor.
Based on the original post and the picture they attached you said the film was removable. Now you are saying the opposite. That's a contradiction.
@Chisolm I hadn't seen your picture originally. We are in the exact same boat. Hopefully someone with an installed video doorbell can verify one way or another.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
