Power Kit on Friedland 115 Stockport
Have an old Friedland chime (0,1, 2, 3), 4 wires coming in. Two wires from 16v transformer go to 0 and 3. Two other wires go to front doorbell are on 0 and 2. Per the Arlo App, the Arlo Power Kit goes on 0 and 3. When I do this I get a slight hum from the chime, even with the Power Kit selected to X. Most of the wiring diagrams I've seen typically have one transformer wire going to the chime and the another transformer wire going to the doorbell itself. Wondering if Power Kit should go on 0 and 2? Thanks for any information.
JP_10,
If you're experiencing an issue with the installation, I recommend contacting an electrician to be sure setup is correct.
For more information, take a look here: Where can I find professional help to install my Arlo Essential Video Doorbell Wired?
Thank you for the response, but this is a question for Arlo as it's a component of the video doorbell system (Power Kit). Using the same doorbell chime, now just need to add the Power Kit...which I have explained the four wires attached to the chime. I tried calling support this past Monday, but was on hold for over an hour and 36 minutes, so I hung up.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
