I have two wired video doorbells which are connected to the same chime box. Connection done same day, one after the other. The front doorbell chimes when the doorbell is pressed but the side doorbell does not chime when button pressed. The side doorbell was connected right after the front doorbell. Both are connected the same way and have identical settings in the app.I have double checked and redone the connections to ensure everything is connected correctly. If I tap the two wires that connect to the doorbell, the chime sounds but not when connected to the device. I am at a loss as to why the side doorbell will not chime. Side doorbell is used more than the front doorbell so this is quite inconvenient. It works well in the app. Thanks in advance for any help in resolving this.
Firmware : 1.14.0.0_1117_c9951d1_b4efa46
Hardware : AVD1001Ar1.2
Purchased 12/4/2021
Does the side doorbell work when the Arlo doorbell wires are disconnected?
@Donsika wrote:
Yes. I disconnected the two wires from the doorbell, tapped the ends and the doorbell chimes.
I think you are saying you tapped the ends on the AVD1001 connection.
I'm asking if the side doorbell works when you disconnect the two wires at the AVD1001.
@Donsika wrote:
It turns out that when the doorbell is operated, the front doorbell pin strikes the plate but for the side doorbell, the pin in the chime did move but was not striking the plate to make the sound. Earlier on it was Intermittent , that is why I was able to get a sound by tapping the end of the wire. Now it never strikes the plate. So the problem is the chime box!!
It could also be that the transformer isn't able to provide enough power for the combination of the AVD1001s and the chime.
So maybe replace the transformer first (generally they are cheaper than chimes, if you are capable of installing it yourself). I'd go with ~40 VA for two doorbells+chime (and use 24 V, 40 VA myself).
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
