I just installed my Arlo Video Doorbell AVD1001-100NAS. Being where my original doorbell was located, I was only able to wire it a certain way (higher than normal). I did not need to use the angle bezel that came with the kit as the forward angle of the camera was dead-on where I wanted it. This being said, I cannot view the inner-most portion of the top step of my porch and also to cut down on the amount of sky it captures (See pic). An angled down bezel would be great if possible to be purchased as an accessory.
It's be nice to be able to angle the doorbell vertically. I'd also like to point mine with bit a downward tilt. No need for me to see the porch ceiling.
Angle down and more side angle are both needed.
My video doorbell is up against a wall and the IR light at night lights up the wall and not the porch. Further, if a package is under the camera, I can't see it... which is why I got this camera.
I agree that an accessory pack with several different angled mounts would be nice, I used a couple of window shims and fashioned my own mount to mount behind the doorbell to get the proper angle that I needed. I also had the problem of Night Vision being too bright since my door is recessed a few inches. I was able to mostly correct the problem using the Pinch and Zoom feature in the Video Settings area.
Brian
I have the need for a spacer with my doorbell. My door frame is recessed from the lannonstone exterior of the house. The view I get would be much better if I could bring the doorbell out another inch. See picture.
I need this too. Not having it cuts off 70% of view. Only one I can find is made specifically for Nest.
https://www.amazon.com/Aobelieve-Plate-Degree-Wedge-Doorbell/dp/B088LY7DWN/ref=mp_s_a_1_10_sspa?adgr...
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
