Have you tried performing a factory reset and onboard again? How do I reset my Arlo Essential Video Doorbell?
Which version of the Arlo Mobile App are you running?
Have you tried to onboard the doorbell over the web portal or another device as well?
Same issue, can't find doorbell in app (both my iphone or wife's android), web app directs to mobile apps. No QR code indicated, doorbell has power and activates chimes. Resetting doesn't appear to help. Verified on 2 G wifi network, ensured WIFI assist off, tried on both iphone and android, turned chime power off/on, reset many times. Oh well, back it goes, might have got a lemon (it happens) but unwilling to invest more time. Strange that can't set up with web app and have to setup by wifi before use of base station. Cameras in backyard were much easier to set up, defaulting to Qcode via app. Some more clarity on light indicator would have assisted. When powered on, doorbell ring, light goes solid white then flashes briefly (10 secs or so) then goes out. Voltage on my current doorbell meets parameters. I'm relatively handy with tech so dissappointed with product setup.
More details, chat with non-bot support limited to subscribers only, bot only directed me to resources (incomplete at that) that I have already tried. Swing and a miss Arlo.
HI @Vfettes
Thanks for the update. I have escalated this for you and someone from customer support will be reaching out to you as soon as possible. I have provided your escalations number here: 42872585
Are you receiving the not "discoverable error screen" after the Arlo log finishes spinning?
Have you factory reset the doorbell per these instructions here: How do I reset my Arlo Essential Video Doorbell?
Yes, received undiscoverable error message on both Android and Iphone apps, reset a couple of times in between. No need to escalate issue as I'm returning it to the store, may be just be a faulty product, will continue to use Arlo with cameras, too bad video doorbell didn't work for me.
So I went through the whole process so many times (got it to accept the video doorbell but not through the base station). I moved base station closer, reset everything, tried it from IOS and from Android apps. Still the base station wouldn't find the video doorbell.
Then I read that the maximum number of *audio* doorbells the base station will take is 2 and I had 2 registered. So I deleted one, and when I started the process again to connect the video doorbell to the base station, it found it quickly. All working now.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
