- Email to a Friend
Hi all,
Looking for advice re new Arlo Doorbell. Everything works fine when all devices are connected to the home wifi network.
However during testing I disconnected my iPhone 8 (ios13) from wifi and had it running using 4g.
When doorbell is pressed the phone rings but when answered does not open the arlo app: it defaults back to the phone home screen.
Is there a setting I am missing somewhere? Maybe within the iPhone settings rather than arlo settings?
Any help appreciated, thank you.
- Email to a Friend
Have you tried rebooting the phone and reinstalling the app?
- Email to a Friend
- Email to a Friend
Deedub,
Check your phones settings to make sure the correct permissions are enabled:
For iOS:
Navigate to phone “Settings”
Scroll down to “Privacy”
Select “Camera”
Ensure that the Arlo app has permissions enabled
Select “Microphone”
For Android:
Select “Apps”
Scroll down to “Arlo”
Ensure that the Arlo app has “Camera”, “Microphone” and “Phone” permissions granted
- Email to a Friend
That seems to have made a difference: thank you.
- Email to a Friend
In ios The Privacy settings associated with "Camera" are for the phone camera, not Arlo.
Microphone: Arlo is listed as an option and was enabled.
Uninstalling & reinstalling seems to have helped. Will need to verify this is stable, though.
Arlo Video Doorbell
