Hello,
I installed the Arlo doorbell today and when the bell is rung, my app gets the call and it works all fine.
But I would like to have a tablet that is permanent inside the house stick by the door, so anyone from the house and use that table to answer the door bell.
I would like to hear from the QA team to know which Android tablet you have tested this with. I like to buy the cheapest tablet there is that Arlo doorbell would work with. I know that I need to look for the minimum requirements, memory, etc. The best bet is a tablet Arol's QA team has tested with.
Can I get a recommendation, please?
Regards,
Shiyam
shiyam198,
Any iOS or Android device should work as long as it meets the minimum OS requirements for the Arlo mobile app. You can find those here: What are the minimum requirements for installing and using my Arlo system?
I have a cheap Fire 7 tablet from Amazon that seems to work well with the app.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
