Installation Power Supply Problem w OLD Chime Wiring
  • 1 Reply
  • 1082 Views
GAMOM88
So, we installed the doorbell, followed the steps but got the orange lights, not enough power message. There should be enough power, however in the diagrams it shows screws on the front, and trans wires. Mine is an old one from the 60's/70/s, there are no screws, it looks like a little clip and the wire just slips in the middle without being secured really. So I have no idea how to install. I tried slipping the little forked ends of the power box in where the existing chime wires are but, its only getting half a connection bc only one tine touches. Support was zero help, just said contact an electrician. Surely there has to be some solution out there. Thanks guys.
Have you located the transformer?  If so, what are its specs - both voltage and VA (or amps if it gives that).
You do need to get it to fit securely.  Most chimes (even old ones) use screws - unfortunately yours doesn't.
Does it fit better if you insert the round metal part around the cable?  Of course, you don't want to spread the clips too much, otherwise the existing wires won't make a good connection.
You could potentially cut off the connectors on the power kit, strip the wires, and twist them together with the chime wiring.  Then insert the twisted wires into the clips.
Note the power kit issue isn't related to the "not enough power" message.  You should get enough power even if the power kit isn't installed at all.
  • 1 Reply
  • 1083 Views
