Get no sound from doorbell ring or motion notification
Try rebooting the phone and reinstalling the app.
What phone and OS version?
I'm using a Pixel 3 XL on Android 10 with no issues. You may need to reset the phone to get the notifications to work.
The ringtone is the same one used by the phone while notifications for recordings are able to be configured specifically for the app (I use Sad Trombone). Do you get either or none? When you check the app settings in the phone settings, click on the Notifications (not the slider) and verify that you show Alerting, not Silent.
BobGorn,
Have you tried something other than the default settings for the ringtone and push notification sound? Does this result in the same behavior?
For notifications I can choose a sound but it has to be the default sound, which I have changed.
Still no sound from Arlo. I'm very perplexed because I've tried all the basic stuff I can think of.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
