Free Week Cloud or better access to local storage ....
I currently had purchased the arlo and another side by side to see how both worked, over the years I started to prefer Arlo’s ability of local backup and have just switched out my ring doorbell for the Arlo Video Doorbell. One thing that’s off for me is the fact that without a paid plan I won’t be able to see who’s at the door if I missed by a few minutes. Arlo can at least give us the same 1 week free for the newer generation of cameras. As I was just about to purchase four of the Arlo Ultras. Also understand Arlo some persons may afford to pay for the plan but due to restrictions won’t be able to purchase the plan especially if they are out of the country. Arlo is Global for the most part.
If you sync the doorbell to a base or hub you can use local recordings without a subscription. You would then use the app to view the local recordings. The ability to view the recordings away from home is a bit tricky, requiring either port forwarding or a VPN so you can access the system over the Internet.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
