Flashing White and Amber
  • 2 Replies
  • 21740 Views
Shinawy
My Wired Video Doorbell was working fine, but I had a problem with it and Alexa, so I thought i'd reset the doorbell.
After simply pressing and holding on the back reset button, the doorbell started flashing white and red/amber.
I can't get it to read the QR code to setup, and it's been flashing for multiple hours now. I reset it multiple times but nothing helps.
Support team is not very helpful so I was wondering if anyone knows what to do.
Shinawy
I solved it.
I disconnected the doorbell, waited an hour, and re-connected it.
Worked like a charm
Shinawy,
After having manually reset the doorbell, did you also remove the doorbell from your account via the Arlo mobile app? If not, remove the doorbell and then try adding again.
Shinawy
I solved it.
Worked like a charm
  • 2 Replies
  • 21741 Views
