My Wired Video Doorbell was working fine, but I had a problem with it and Alexa, so I thought i'd reset the doorbell.
After simply pressing and holding on the back reset button, the doorbell started flashing white and red/amber.
I can't get it to read the QR code to setup, and it's been flashing for multiple hours now. I reset it multiple times but nothing helps.
Support team is not very helpful so I was wondering if anyone knows what to do.
I disconnected the doorbell, waited an hour, and re-connected it.
Worked like a charm
Shinawy,
After having manually reset the doorbell, did you also remove the doorbell from your account via the Arlo mobile app? If not, remove the doorbell and then try adding again.
Worked like a charm
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
