  • 3095 Views
PetaH
I just got my doorbell installed and I keep getting a notification stating my camera is been tampered with. How do I fix this?
That may be due to a weak transformer or out of spec voltages. Did you test the transformer voltage before installing? Are you sure the connections on the doorbell are secure?
PetaH
I will check this thank you, I haven’t got a chime set up and some one told me it may be due to this ?
I don't have a traditional chime and it works fine. Make sure you didn't use the power adapter thingie which is for a wired chime.
  • 3096 Views
