Arlo Video Doorbell Mounting Position
I was thinking about getting an Arlo Video Doorbell. However, the siding on my house won't easily allow vertical (up and down) mounting as shown in the video. If you mount this thing horizontally, will the video be rotated 90 degrees, or is there a setting where you can adjust that.
wuzzy1,
There is no setting for the Arlo Video Doorbell to rotate the image. Mounting the doorbell horizontally will result in the live stream / recordings also being rotated 90 degrees.
Lacking the ability to mount the doorbell in a horizontal position with a software correction for orientation is a deal-breaker for me. I also have a front entry limitation that prevents the standard vertical mountings without some kludgy backing to make it fit in a vertical position.
I just received mine and am debating if I can somehow create my own mount for the same reason. I was searching for youtube for some ideas since I assumed this must not be an isolated problem. All I could find was that the Ring product comes with adjustable mounts for both horizontal and vertical planes. I contacted Arlo so see if perhaps they would suggest something I had not considered or perhaps now have a vertical 'wedge' but unfortunately, they do not. i'm going to see if I can easily craft a solution, but I'm a bit disappointed that I will likely have to return the doorbell.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
