Existing chime won’t stop chiming
What Friedland chime model do you have?
Although Arlo doesn't have a compatibility list for chimes, Ring does (and generally if a chime is works with Ring, it will work with Arlo). Look for your chime in the list here: https://support.ring.com/hc/en-us/articles/209028546-Ring-Video-Doorbell-Pro-Chime-Kit-Compatibility...
Thanks.
I checked the two Friedland chimes in Ring compatible chime list. My chime does not look like these two. it is more than 20 years old. I could not find model number. So The chime could be the issue. I was thinking to use Alexa speaker as chime.
My transformer is Nutone 16V 10VA. Is transformer good? Enough voltage and power for Arlo doorbell?
No idea on it's current status. But it is within the spec for the AVD1001.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
