  • 7 Replies
  • 1725 Views
PC01
I have a VMB base station and several cameras that are successfully recording to Direct Storage device but I can’t get the doorbell to record. I have tried setting up a rule but the record option is grayed out. Is there a workaround or do I need an upgraded base station?
7 REPLIES 7
PC01
VMB4000
Sthpaw01
I also saw my doorbell not recording to the cloud. I do not have a subscription service. I was wondering if connecting my hub to direct storage was the way to go to fix my problem but apparently you are having a problem with that. I would like to know the answer to this problem with the doorbell not recording video at all for us.
Edit: I see this product has a new firmware update from 2/22. My assumption is Arlo broke the recording feature on the doorbell with the new firmware.
@PC01 wrote:
VMB4000
The VMB4000 doesn't support direct access to local storage.  You need to remove the USB storage and connect it to a PC to see the locally recorded footage.  All the footage you are seeing in the app (and my.arlo.com) is in the cloud - which requires a subscription for the video doorbells (like all newer cameras).
What base model do you have?
Not the issue for @PC01 (assuming the VMB4000 is the correct base).
PC01
Yes I have a VMB4000 and I remove my USB and can see everything but the doorbell recordings and the software does not allow me to use the record option under the doorbell settings.  I gather that there is no way or backdoor way of recording the doorbell to the the USB storage without a subscription. Would getting a VMB 4500 or VMB5000 make a difference?
Sthpaw01
Hub model is VMB4000.
I had video recordings working on it about 2 weeks ago and now all I see is the notifications about motion without the recording of it. That is why my assumption is Arlo broke video recording with the new firmware release.
Edit: Or did my trial run out? I installed it in the beginning of Nov last year. You said the video doorbells require a subscription to record to the cloud so maybe its because my trial is over?
Is the doorbell connected to the VMB4000?  Or is it connected to your home wifi?
  • 7 Replies
  • 1726 Views
