I read a while ago that an update would be available in April 2021 so I could connect Arlo doorbell to older version base station. I can not find the article now so wondered if anyone could update me on if it will ever be possible to connect the doorbell to my older base station which would give me recordings without the need for a subscription.
thanks
Thank you for your help 🙂
I don't recall seeing any post about connecting the video doorbell to the VMB3010.
Though even if they did this, you'd need to eject the USB drive in the base and connect it to a PC to view the recordings. The VMB3010 doesn't support direct access to local storage.
Oh OK thanks........Although I do view all my currently set up cameras recordings and live through the base station on my app?
The recordings you are seeing are saved in the Arlo cloud - they aren't locally saved recordings. The reason you get them is that the Pro and Pro 2 (and the original Wirefree) cameras came with 7-day free cloud recording, and Arlo still honors that. Newer cameras (and the doorbells) don't offer that benefit, so they need a paid subscription for cloud recording.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
